NH 451 Mower Top link kit
Kelly Campbell
06-26-2007 06:35:56
Does anyone happen to have the adaptor kit for a NH 451 mower that goes in between the toplink on the tractor and where the 1st yoke is on the mower, if so I"d like to see some pics of it. I purchased one over the weekend and it will not fit between the arms coming off of the rock shafts on my tractor.
Thanks,
Kelly
MLD
06-28-2007 05:57:48
 Re: NH 451 Mower Top link kit in reply to Kelly Campbell, 06-26-2007 06:35:56
You must be tring to hook it too a very tiny tractor if it doesn't fit between the lift arms?? I use mine on 1010 john deere & it does a good job.
Kelly Campbell
06-28-2007 06:50:59
 Re: NH 451 Mower Top link kit in reply to MLD, 06-28-2007 05:57:48
Actually its a 50 hp Kubota, but yes your correct.
Kelly Campbell
06-27-2007 03:56:52
Problem is that the front "Yoke" of the 451 will not fit between the bars that come down off of the rockshafts on the tractor, the space is two narrow. New Holland makes a kit to fix this issue and was hopeing someone had run in to this before.
Thanks,
Kelly
banjo
06-26-2007 21:07:53
If i had a camera i'd take a picture of the one on my tractor right now.
it should all be with the mower already as stated. take your top link off the tractor. hook the mower to the tractor then use your top link you just removed from the tractor and place it between the two.
you will have to release the two levers on each side to pull the sliding part up to hook the top link up. now re hook the eye hooks so the 3 point will lift it as one unit. i'm sure it sounds harder than it is.
Kickinbull
06-26-2007 12:52:15
Not sure what you're looking for. On ours, we put the yoke top link from the mower on the tractor. Then take your top link to go between that and the mower.
