Ford 532 Baler clutch discs
Puffie40
06-23-2007 23:47:08
I took apart the clutch and flywheel of my 532 Baler because last season, It disconnected too quickly under heavy loads.
The problem soon became obvious: one main disc was nothing but splinters,the other was kinda thin, and a little damaged.
I think I can throw it together with another disc from a parts baler and get this year's haying done, But I would really like to find another (Preferably new) set of clutch discs.
Is there another source for clutch discs? I am kinda hesitant to go to the Ford dealer because I heard parts for these balers is out of this world.
Thanks,
Chris
A-C hayman
06-25-2007 19:43:39
 Re: Ford 532 Baler clutch discs in reply to Puffie40, 06-23-2007 23:47:08
seems like the ones I bought this spring were about 40$ EACH. bout two years ago they were about 15$ each. I have to buy a set almost every year
RodInNS
06-24-2007 00:55:46
I don't recall that they were too bad, but it's a few years since I bought them. NewHolland is the quickest, easiest source. Otherwise, I'm sure you could match them up with some standard Weasler driveline stuff. It's no big deal...
Rod
Brown Dirt Cowboy
06-24-2007 14:12:39
 Re: Ford 532 Baler clutch discs in reply to RodInNS, 06-24-2007 00:55:46
What years was the 532 balers made? thanks. Tom
RodInNS
06-24-2007 14:36:54
 Re: Ford 532 Baler clutch discs in reply to Brown Dirt Cowboy, 06-24-2007 14:12:39
Not sure on that exactly. Ours was about an '80. I'm guessing from the mid '70's up to around 80 or 81....
Rod
Brown Dirt Cowboy
06-24-2007 15:01:59
 Re: Ford 532 Baler clutch discs in reply to RodInNS, 06-24-2007 14:36:54
RodinNS thanks for the info, the reason I asked was my neighbor has an operator's manual for a 532 and 542 baler and asked me if I knew when they were made. Thanks again. Tom
