JD #9 sickle bar
fire_lt133
06-23-2007 19:44:02
two questions, I am new to using sickle bars and I was wondering if there is a simple reason why the bar gets clogged no matter what speed I go. Is a dull blade a likely culprit? The other question is how much is a JD #9 worth in upstate NY if it is in good condition?
Clarkbug
06-24-2007 12:09:32
 Re: JD #9 sickle bar in reply to fire_lt133, 06-23-2007 19:44:02
As a frame of reference, I just bought two JD #5 mowers, and I am from Upstate NY (about an hour north of Albany). I paid 300 for both of them. One was pretty worn, the other is in real nice shape, just needs some paint. So, I have a working mower, and one for parts.
dds-inc
06-23-2007 19:47:20
#1 reason is running a loose knife. you need to keep the knife down on the guards so that there is no slack by bending the tabs.
#2 reason- knife is dull. Use angle grinder to sharpen.
#3 reason- excessive decaying thatch in the hay will clog a bar up anytime. Use only when thatch has rotted up and sunk in.
msb
06-24-2007 18:38:18
 Re: JD #9 sickle bar in reply to dds-inc, 06-23-2007 19:47:20
#4. ledger plates worn out.
