trailer mower
jason burke
06-21-2007 15:41:40
I have a new idea sickle bar mower that is trailer type with NEW IDEA PLOT NO.72 on a metal tag on it. Is this the model no.? I need help with the rope trip on it.I mowed about 2 acre with it the other day and it worked fine then 2 days later was mowing around the sides of our road pulled the trip rope mower lowered as it should but went to trip and raise the mower but cannot get it to raise. thought it might be a pin in the rope lever but it is fine. any ideas??? any and all help would be appreciated thanks
Leroy
06-24-2007 09:28:05
 Re: trailer mower in reply to jason burke, 06-21-2007 15:41:40
With your lot no. it would be an older No. 30. What could be the problem is under where that spring is located is a large cast gear with notches on the inside for the clutch and teeth on the outside that run against a worm gear to provide the power for the clutch. I just got a slightly newer model that those outside teeth were ground off and I have a junk No. 30, Lot 100 that I plan on trying to take that gear out of and hope it is good to put over in the one that I just got. Haven't had time yet but if it works the mower will be avaible for sale
Allan In NE
06-21-2007 17:34:18
Yep, what Jerry said,
That spring inside the lift housing is broken.
I've fixed a lot of those lifts on all kinds of machinery and it is always that darned spring.
Allan
jason burke
06-21-2007 19:24:30
 Re: trailer mower in reply to Allan In NE, 06-21-2007 17:34:18
thanks that helps out alot. my next question is why is the hay bunching up in the bar about every other round?is it the highth i have it set at or the tilt on the head or leading out-in to much i really appreciate it thanks this year is the first time i have used this a trailer type mower is my tractor to fast,slow im using an h farmall
kelly campbell
06-22-2007 08:50:06
 Re: trailer mower in reply to jason burke, 06-21-2007 19:24:30
do you have a two blade end section on it?
Kelly
Jerry Coulter
06-21-2007 16:13:32
New Idea used Lot # like other mfg use serial number ranges. You likely have a model 30, 30A, or 30B. That # should be on the tag also. My mower acts just like yours now. There is likely a broken return spring inside the clutch. Need to remove the bowl shaped cover and look inside. I just use a bunge cord to tie the lever back.
