Rakes with dollys
Lincoln
06-21-2007 13:37:41
I am looking for a new hay rake. What are the advantages or disadvantages with a rake with a dolly on the front verses a regular hitch. Thanks
James Howell
06-22-2007 10:30:36
 Re: Rakes with dollys in reply to Lincoln, 06-21-2007 13:37:41
I have two JD 640 rakes; one with a dolly wheel and one without.
Dolly wheel rake is easy to hitch to tractor drawbar, but a pain to back up with the tractor.
Dolly wheel rake is easy to move around without a tractor; I push and the favorite wife navigates.
msb
06-21-2007 19:08:02
Advantage: Takes the tractor front wheels out of the equation.e.g. Hit a hump with the front wheels cause the rake to dig in and vice versa. rake teeth are more closely regulated in regards to the soil conditions,much easier to hook up to tractor.
Disadavntages: One more wheel to go flat,& as stated, another wheel running over the hay and knocking leaves off ,especially if the hay is too dry.
If your fields are relatively smooth, then go without.Undulating or rough, go with a dolly wheel.
paul
06-21-2007 16:52:55
See very few dolly setups here in alfalfa country, the less wheel traffic on my hay the better.
--->Paul
Blue guy
06-21-2007 15:20:45
I've used both. The dolly does follow the ground better, but I prefer to just use the drawbar. I can make slight adjusments from the tractor seat, that comes in real handy if you have a few rough spots in the field. The regular hitch is also easier to back up. You can't go wrong with either one though.
georgeky
06-21-2007 13:51:58
You can also make tighter turns, they are better all the way around. New Holland is the cream of the crop in rakes.
55 50
06-21-2007 14:49:38
 Re: Rakes with dollys in reply to georgeky, 06-21-2007 13:51:58
I have a JD 894A without the front dolly and I can make very sharp turns. Seems to me that the dolly would restrict turns somewhat. Of course that"s related to how far out the tractor drawbar is. I have mine out 14 inches because that"s what my baler needs.
georgeky
06-21-2007 15:46:57
 Re: Rakes with dollys in reply to 55 50, 06-21-2007 14:49:38
No it does not. You can turn and one wheel of the rake will pivot right where it is. You are pointed in the other direction.
dboll
06-21-2007 13:44:24
hooking up, following ground contour better and adaptable to pulling multiple rakes, New Holland would be my first choice followed by JD
