JD knotter question
JWK
06-21-2007 04:27:38
I was blowing the dust off the knotters on my 224T baler and noticed the "balls" on the end of the knife arms were shiney and have some flat spot wear from riding the knotter cam.
Are these "balls" supposed to actually be rollers that roll along the cam instead of slide? Right now they're stuck fast.
JWK
06-22-2007 19:41:53
 Re: JD knotter question in reply to JWK, 06-21-2007 04:27:38
Finally had time to get back to the computer.
Many thanks. I figured they were supposed to roll. One more thing to add to the repair list.
It ties just fine, but I'd rather fix those things than have to replace the cams.
Thanks again.
Gene-WI
06-21-2007 15:21:18
Don't know about the 224t but on my 336 it has rollers that turn, your's must be frozen
Rexalot
06-21-2007 22:36:20
 Re: JD knotter question in reply to Gene-WI, 06-21-2007 15:21:18
They should roll, not slide along. However, doesn't mean that the knife arm won't do it's intended function, but at some point you may experience problems.
Some knife arms they are replaceable, others require a complete assembly.
