Silly Question I am sure
patsublett
06-20-2007 18:42:44
I am rebuilding a sickle mower & saw on the sickleservice website a listing for wear plate.
some 6" long & some several feet long. My Silly Question is what is a wear plate on a sickle mower?
Finn Md
06-21-2007 10:03:12
 Re: Silly Question I am sure in reply to patsublett, 06-20-2007 18:42:44
wear plates are used to keep sections in straight alignment. The wear plates rub against the back of the sections. They are available at most tractor parts stores, and they are flat pieces of metal fixed to bar. You don't want the sickle bar to move sideways at an angle. When they get worn you can often flip them over.
Leroy
06-24-2007 04:51:55
 Re: Silly Question I am sure in reply to Finn Md, 06-21-2007 10:03:12
Never seen one you could flip over, they have two ware edges, one on top and a second on the front edge and if either gets worn then you will have cutting problems
Finn Md
06-25-2007 10:30:32
 Re: Silly Question I am sure in reply to Leroy, 06-24-2007 04:51:55
my "old" Ford 515 mower originally used flat wear plates, no curved lip, that you could flip and use other side when they got worn. I agree, seems newer "universal" wear plates you can't do this.
Leroy
06-25-2007 19:13:17
 Re: Silly Question I am sure in reply to Finn Md, 06-25-2007 10:30:32
That 515 mower is new for me, mine are all older and on McCormic, John Deere, Oliver, Moline, Ford, David Bradley, all mowers I have had and combines Deere, AC, and Massey Harris all had that lip. that controls the forward back movement of the knife and without that there is nothing to keep the knife back from chewing everything else up.
Ric KS.
06-20-2007 19:20:33
Under the sickel where the back side slides against the bar there is sometimes a angle strip that lays between the sickel and the bar, most all bar mowers had them until the newer stile guards
