1219 haybine noise?
jdjack
06-19-2007 16:39:49
I have a jd 1219 haybine. Are the rollers suppost to be noisey? I adjusted the rollers running and no hay going through it. But it seems lke they make alot of noise, maybe it's normal?
Seems to be quiter with hay going through them.
Roger in Iowa
06-19-2007 19:28:46
 Re: 1219 haybine noise? in reply to jdjack, 06-19-2007 16:39:49
How did you adjust them? Are they running together? They are not supposed to run together!
You adjust while running. Adjust until noise starts. Open the rolls until noise stops then add additional part or full turn, I don't remember. Read the OM.
They are quieter when hay is going thru.
Roger in Iowa
