Building a 2 wheel track road.
Edd in Ky
06-14-2007 19:13:15
I want to build a 2 wheel track road across 900 feet of former woods and brush fields. The top soil is good and deep, from years as a forest. It is high ground, no marshes. I'd like to know your experiences with a project like this.
For example, do I need to remove all the top soil so the gravel road won't sink? I can put down Geo-cloth and pour 6" of gravel on it ...how long wlll it last? Are any of the common farm implements of any help in cutting the wheel track ditches. Do I even need wheel track ditches?
Traffic won't be heavy..just cars, pickups and an occassional hay wagon or horse trailer.
I'm sure some of you have done this. What did you learn?
Many thanks, Edd
johns48jdb
06-17-2007 19:42:36
 Re: Building a 2 wheel track road. in reply to Edd in Ky, 06-14-2007 19:13:15
ed, your close enough to al to maybe know what cert is. its red clay with rocks in it and makes a good sub base for most roads around here. drive on that for a while and the added crushed stone as needed. normally around here the cert is the only thing needed. don't put the road any where near any place you take out a stump. it will take years for the hole to fill in and become stable enough to drive on unless you pack it full of some big rocks first and the add crused stone on top of that. just puting in dirt will never dry it up for a lone time. just don't ask my boss about me driving his 8630 off in a stump hole that had been just filled in with dirt for about a year. ok?
Bob Kerr
06-15-2007 15:50:52
Back in about 74 our family built a half mile road through woods that goes up and down hils and across a creek. we just did light grading to make about a 6 inch deep ditch 3 feet off to the side of the tracks and used that dirt to make a crown in the road. Make sure to put places for the ditch water to get away. We did have to pay attention to where water would run on the hills so we wouldn't have it get washed out everytime it rained. We used #2 crushed stone in low spots and on the hills. We then put (I think they were #53) finer grade stone down and only 2-3 "deep total. Some people like the stone with rock dust in it as it packs well but it has a tendency to make pot holes. I think a road made from stone with no dust holds up better(lets ground dry under the stone) and costs less to truck. We have to grade the hills every 2 years and the rest of the road only needs it ever 4 or so. The more traffic you have the more you will have to grade it though. Oh yea, one more thing that is important. If you are cutting the trees out make sure you cut the stumps off as close to the ground as you can or better yet pull them out. they will stick up high as the rest of the road gets packed down and settles and can snag your grader blade and small dia stumps can punchture a tire!. Good luck with it.
BCnT
06-14-2007 21:19:17
i use a 2 bottom plow to form ditches and move dirt to center of road...then finish grade it with a 3 point blade...the ditch helps keep center of road from holding water and getting soggy...a 6'' bed of clay followed by a few inches of gravel will build you a solid road for many years.
