1219 haybine
steve H
06-14-2007 07:46:30
I am having trouble with breaking sickles, they break right next to the head. Any thoughts as what might be causing the problem?
caterpillar guy
06-15-2007 05:24:42
 Re: 1219 haybine in reply to steve H, 06-14-2007 07:46:30
Steve we had the same problem we put in a new knife and the pin was loose in the socket bearing also the pin was woren some. We are going to replace the pin and the arw if it is available as it is not right either. I would guess that is the same issue on yours.
johns48jdb
06-14-2007 16:28:35
is the blade in time? are all the mounting bolts tight that holds the wobble box on? i had a 990 ih that did that and it drove me crazy. if you find your problem would you em me or add to post. thanks.
Roger in Iowa
06-14-2007 10:52:21
The first few guards (3) are special or different. They do not have the rear wear bar. The sickle as it moves left to right also has to move fore and aft because of the arc of the drive arm. The wrong guards will not let it move fore and aft. Look in the OM.
Also, did you replace the drive pin or is it the tie rod end type. If the pin or rod end are worn and let it hammer, that can break sickles also.
Roger in Iowa
steve H
06-14-2007 11:11:32
 Re: 1219 haybine in reply to Roger in Iowa, 06-14-2007 10:52:21
Thanks Roger, I do notice play in the drive pin, I will try replacing that.
Tx Jim
06-14-2007 11:32:46
 Re: 1219 haybine in reply to steve H, 06-14-2007 11:11:32
Steve,also besides loose pin be sure pitman arm is tight on wobble box. Tx Jim
