JD 24WS baler
Hoosier Pete
06-12-2007 14:47:09
Just got it home. Look'in it over and the drive chain on PTO shaft on the front of the baler has used up all threads on adjuster. IF I remove a link from the chain does the baler need to be retimed?
Thankx, Pete
Tx Jim
06-13-2007 04:39:13
 Re: JD 24WS baler in reply to Hoosier Pete, 06-12-2007 14:47:09
Pete,if flywheel doesn't turn and you don't remove chain from sprockets,some links could be removed on chain on area where adjuster is without affecting timing. But I would recomend checking timing as previously stated. You nedd to check feeder forks and needle timing. Tx Jim
Roger in Iowa
06-12-2007 19:30:28
Yes. Needles and other parts are expensive not to do it.
Roger in Iowa
