Hay Rake Bearing Source - Lely or Vicon
Scott Appel
06-12-2007 08:50:32
I'm looking for a source for replacement journal roller bearings for my Lely 8 wheel rake. Measurements are 1 3/8 ID, 1 3/4 OD and 2 inches long. They are a caged roller bearing with 6 sets of three 3/16 diam needle type roller bearings. Cage end caps are held together with 6 pins spaced between each set of 3 rollers. Any idea on where I can get more? Newer rakes use tapered roller bearings. thanks,
Scott (can e-mail pics if needed)
Clefus
06-13-2007 19:08:37
 Re: Hay Rake Bearing Source - Lely or Vicon in reply to Scott Appel, 06-12-2007 08:50:32
Try a bearing supply place...
I picked up a pair of axle bearings for my IH 35 rake....old bearings siezed up and tore things up...I removed the outer and inner races....they were Timken....and the bearing dealer knew what was missing by the part numbers..
