side delivery rake
MN Bob
06-11-2007 15:34:50
Found an old JD LR 2 5wheel today. Bought it right but it is missing the adjusting link on the front. Fellow told me he always used a 1 inch turnbuckle, I have only seen one other and it had a hydralic cylinder on it. Anyone know what is original? Tried JD parts but couldn't find the old rake on it. Thanks, Bob
MN Bob
06-11-2007 15:52:58
 Re: side delivery rake in reply to MN Bob, 06-11-2007 15:34:50
Just went back and read some old discussion on the LR 2. Seems most opinons were that there was no such thing. Say it must be a 858. Mine is rubber tires, 5 bar. Gear case. Its in good condition except for the missing adjusting link. The brass tag says LR 2 (5) 15476. The 5 in () is hand stamped, I assume becasue it was assembled as a 5 bar rake. Information on this would be welcome, so would good pictures of original paint scheme. Bob
Hayfarmer
06-12-2007 07:25:21
 Re: side delivery rake in reply to MN Bob, 06-11-2007 15:52:58
That number of the cage always throws you off. I think the adjusting link was meant to be a cylinder, would have to be long, or a ratchet jack or hydraulic jack. You might want to get an operator's manuel at least from JD and parts book helps too. Not that expensive. I have one of these but mine was altered to be sued on a tractor 3 point with hitch bar and is raised and lowered that way. Mine is a 4 bar and was all green with yellow wheels. Later ones had the carrier "yoke" painted yellow.
