NH Super 66 baler ?
westernpafarmer
06-10-2007 12:02:55
Having trouble getting the bales to be even..The bale curves....Only on the inside knotter..... Have ajusted the string tension,knotter tightness and tension on the back inside of baler????And the inside string still is loose on the bale....Any thought or steps to reset something???Thanks to all. Scott
Scott PA
06-10-2007 17:50:57
 Re: NH Super 66 baler ? in reply to westernpafarmer, 06-10-2007 12:02:55
Do your bales want to hang together on the pickup side? If so you have too much clearance between the plunger knife and stationary knife and it pulls the hay to that side instead of cutting it off clean, the wood rails on the plunger may need replaced.
Ozarker
06-10-2007 16:21:36
It is sounding like a balecase feed issue. The hay could be pushing too far into the balecase to form an even flake when the plunger makes a compression stroke. Adjustment can be opposite of what you think it should be. On my 278 New Holland you move the feed tines away from the balecase to move the hay further into the balecase. They need to pick up a "bigger charge" to properly fill the balecase. Took me a long time to grasp that concept. Lots of "discussion" with the dealer's service department. Can also be caused by really small windrows or windrows that are inconsistant.
R Aiken
06-10-2007 13:26:04
You have banna bales, not gitting enough hay in
the chamber. Either rake larger windrows or
drive faster. Also could be that your wadboard
is pushing the hay in too far. Check that the chanes are right.
