336 baler needle roller picture
Gene-WI
06-06-2007 08:01:45
third party image
I got the old rollers out of the needles and new ones installed, what I did was take a die grinder with a carbide bit and ground the head of the rivet untill I could see where the shank was,then I used a drill with different size bits till I could drive the roller out the slot. When I put the new ones in I heated the end of the rivet so I could mushroom just the end without swelling the whole rivet so the rollers would turn. Thanks to everyone who gave me ideas on how to go about removing them. Gene
Gene-WI
06-06-2007 11:05:29
 Re: 336 baler needle roller picture in reply to Gene-WI, 06-06-2007 08:01:45
third party image
Well Roger I can take care of that problem right quick if you're sure they aren't supposed to turn,I'll just squeeze them a little with my haybine riveter till they don't turn. Here's a picture of the rollers, worn one's on the right.
Roger in Iowa
06-06-2007 13:09:12
 Re: 336 baler needle roller picture in reply to Gene-WI, 06-06-2007 11:05:29
You got the goodie out of that one!
You might get by with plastic twine and the roller rolling, but sisal and all its individual fibers will "go over the edge" of the roller and give you fits.
I believe if your roller had been rolling it would long ago have worn thru the rivet.
I'd tighten it down so it did not roll.
Regards,
Roger in Iowa
WyoDave
06-06-2007 17:52:59
 Re: 336 baler needle roller picture in reply to Roger in Iowa, 06-06-2007 13:09:12
I'll second that idea. Been around Deere balers for along time, baling alot of hay, and I've never seen one that rolls. I will agree yours needed replaced though.
David
Roger in Iowa
06-06-2007 09:23:34
Gene, you went to a lot of trouble to create more trouble. The rollers are not supposed to turn in twine balers. They are used because they are harder than the cast needle and act only as guide and wear surface. Now when they get a little worn, twine will be caught between the sides of the roller and needle and cause you lots of stress!
Wire tire balers do have needles with rollers that roll!
Roger in Iowa (retired from JD factory that built the baler)
14T
06-07-2007 21:28:02
 Re: 336 baler needle roller picture in reply to Roger in Iowa, 06-06-2007 09:23:34
Thank you Roger and Gene. I'm getting a 14T back into shape and was going to order replacement rollers. Going to skip that for now.
