Goosneck Trailer Susupension
Jerry/MT
06-05-2007 10:35:05
Can anybody comment on the preferred suspension system for a 14K GVWR gooseneck trailer? Slipper springs or torqueflex axles????
BCnT
06-07-2007 11:07:15
 Re: Goosneck Trailer Susupension in reply to Jerry/MT, 06-05-2007 10:35:05
got a neighbor that swears by torsion axles...he has em on a 30' cattle trailer that NEVER has seen a easy life and also on a 25' gooseneck that he hauls a 450 case dozer and a 580ck backhoe...guy owns a oil field lease service so smooth roads aint only thing his trailers see.
CWL
06-06-2007 10:51:18
Slipper springs are more forgiving if the trailer is not set to pull level. Torflex systems generally bolt to the frame directly and need to have the trailer coupler adjusted so the trailer sits as level as possible. As far as strength the only bad thing that I have heard about torflex axles is they don't work well on three axle trailers. Supposedly the center axle is prone to fail for some reason. Who knows.
jmixigo
06-06-2007 03:30:53
I assume you are refering to flat bed equipment type trailers. The torqueflex rubber based suspensions are a mite fragile compared to springs. They do fine under horse trailers and campers, but don't take abuse too well.
