Big carrier spring MF 41 sickle mower adjustment
Edd in KY
06-04-2007 18:57:31
I have moved the adjustment of my MF41 mower out to the widest bolt locations (for wide wheel base) but can't seem to find anything in the manual to help me set the right adjustment for the big spring that apparently carries a lot of the weight of the mower blade.
Any help or insight wpould be appreciated.
mn.Chuck
06-04-2007 19:33:19
 Re: Big carrier spring MF 41 sickle mower adjustm in reply to Edd in KY, 06-04-2007 18:57:31
Edd, Should show on pg 8(assembly instructions)
and on 14-15. For the wide setting the distance
between the bottom edge of the swivel(under head
of adj. bolt)to the top of the spring threaded
plug should be 9-12 inches. Outer weight of the
cutter bar should be from 20-40 lbs and weight of
the inner bar 90-120 lbs. Hope that helps. Chuck
