Sickle Knife hold down clip adjustment
Edd in Ky
06-04-2007 18:49:34
I know you old pro's can do it by feel, but if I am adjusting knife hold down clips.. can you give me an idea what kind of spacing is right? 40-1000's? Thanks Edd
mn.Chuck
06-04-2007 19:38:15
 Re: Sickle Knife hold down clip adjustment in reply to Edd in Ky, 06-04-2007 18:49:34
Edd, Put string along point of guards to be sure
aligned. Then 0.010" clearance is the ideal. On
pg.24. Good luck Chuck
Roger in Iowa
06-05-2007 13:13:45
 Re: Sickle Knife hold down clip adjustment in reply to mn.Chuck, 06-04-2007 19:38:15
String is a good idea, but put it along the ledger surfaces. Tips of guards may be bent but ledger is okay. Or may have to bend tips up or down to get ledgers on the same plane.
Roger in Iowa
