Disc for 9N
mad farmer
06-03-2007 13:59:09
Am comtemplating getting a disc (new?) for my 9N.. Need to do large gardens (1/2 acre) and small plots of ca. 2-3 acres. I have the original ferguson 2 bottom plow (dialmer-benz mfg.) that came with the tractor to break things up. The gardens are loosely tilled soil, the other plots will be sod busting.
Any suggestions for a harrow? Have not seen one recently at local auctions of proper size and prefer 3pt type. Hydraulics are fine so lifting implement up to max size is fine (1000 lbs ?)
old
06-03-2007 16:10:40
 Re: Disc for 9N in reply to mad farmer, 06-03-2007 13:59:09
6 foot tandem disk should work well if its not to heavy. I used one on one of my 8Ns but I had to remove one of the wieghts I had on it because the front end would not stay on the ground
