I'm kinda curious where you guys get replacement rims if you need them for your wagons, and other equipment-Last year we trashed a 4 bolt rim on our springtooth so I went to our loacl source, who is a private scrapper with a nice tire pile in back. I found 1 nice 4 bolt 15" rim with a good tire on it, got it for $10. A little while later I needed a 5 bolt rim for a running gear I fixed up, as the one rim was not original and the tire was burnt anyway. I went back out there and got 4 more tires & rims, 1 had a shot tire on it and another one blew the tread off in the sun once I got home, but again I got them for $10 each, 3 had hubs/spindles still attatched too. I was bringing in some scrap iron later on and the scrap yard also has a large selection of rims that guys will remove the tire then scrap the rims. I got 2 more 4 bolt 15" rims, 2 5 bolt 15" rims, and another odd ball 6 on 6.5" 16" rim that matches one of our hay wagons. I got them all for scrpa price because after I unloaded, I threw them in my truck and went back over the scale. I was just there again on Wed. and pulled out a nice 6 bolt 15" rim. one hole is bent a little bit, but it can be pounded out. I'll probably mount it on a hub and spin it first just to check, but it should be fine under a hay wagon. We don't nessesarily need all of those rims, but I always look and If I find one that is what we use and matches, I'll grab it. It's also nice to get rid of the 14" rims on the farm. We've got absolutley no use for them.... Donovan from Wisconsin
