Need part # - JD 350 mower
RayP(MI)
06-01-2007 19:08:58
Need the part number for the cylinder plug thingy that attaches to end of wobble drive arm, sticks down into end of sickle bar. Drives sickle bar. About 1" in diameter, 5" high with grease nipple on top. Groove around circumference to match where bolt goes thru wobble arm.
Is there an on-line site where I can order JD parts directly, or do I have to go thru JD dealer?
Thanks, Ray
RayP(MI)
06-02-2007 17:27:19
 Re: Need part # - JD 350 mower in reply to RayP(MI), 06-01-2007 19:08:58
Thanks, Bob - don't have the serial number at hand, mower is at another farm... Bought a new sickle bar (knives) thru TSC, and wonder if the socket will make a difference. New one has needle bearings in socket, first one didn't, one I broke last year did. Bearing failed too, which is why I probably need new pin!
Bob
06-02-2007 02:43:11
You can sign up at jdparts.com, but you will be "hooked up" with a local dealer. Parts you order go through them, and the dealer bills you.
Third Party Image
Looking for part Key #2 or 2A?
2... Part #H62221 PIN FASTENER Serial number up to -800000 (SUB E83014)
2A.. Part #E83014 PIN FASTENER
So, the current part # is E83014 @ a little over $20.00.
Shoup's, or one of the other independent parts companies MAY have them, too.
