wire winder
spitz
05-29-2007 11:16:36
anyone know of an easy way to wind up electric fence wire in the fall or have plans to build a winder of some sort. The commercial ones I see are expensive and dont look too bad to build but I need someone with some experience to see what features should be on it. Thanks
Bret4207
05-31-2007 12:22:27
 Re: wire winder in reply to spitz, 05-29-2007 11:16:36
Just get near it with the bush hog. You'll wind WAY more wire than you'd think you can!!!
Grub
05-30-2007 09:59:15
Have the guys at your local steel fab shop save you the plastic spools from their wire feed welders (the big rolls). Those are handy for wrapping up all kinds of "loose ends"; extension cords, twine, wire...
Grub
Gary from Muleshoe
05-30-2007 08:49:46
We used to take off one rear wehll of our old GMC pickup and put one on without a tire. Get it started by hand a few turn slip in first gear and let her. we would wind about a mile at this way.
spitz
05-30-2007 05:38:48
Thanks for the ideas! That looks like a slick outfit! Hoping to put something together before fall so the deer dont run through and tangle the wire all over the grove! Thanks again!
Fern(Mi)
05-29-2007 18:59:56
Hi spitz:
I wind between 6 to 8 miles wire every spring with my ground driven wire winder. Two Educated engineers have continuously denied it's working. Yet it works for me the last five years. But what do I know? Here's a couple snaps.
third party image
First day�s start late March, 2006. I had rolled eight miles wire last year, in to partial days, between morning and evening chores. third party image
May I add I built this whole rig. Guaranteed one of a kind HM machine.
You may E-mal me for details more pics if I need to take them.
Edd in KY
05-29-2007 16:15:16
One of our local farm stores rents theirs for $3 per day. It is manual, no motor, and works like a charm. Sure beats buying one.
peaster
05-29-2007 11:46:53
I built one using a transaxle out of an old lawn mower, some pulleys and belts, and some square tubing. It runs off the pto of the tractor and mounts to the 3 point using a drawbar. Its not real heavy duty but it got the job done on a 1/2 mile of wire I had out. Its nice to be able to change speeds and put in reverse while rolling up wire.
bjb in ne
05-29-2007 11:35:37
My grandfather has one he built out of an old hand grinder and a tiny gas engine from an old lawn mower.
