Case IH 3450 Round Baler
MAH
05-29-2007 09:17:44
I purchased a used Case IH 3450 baler this spring and I finally got to use it in the field last week. There are a couple of what I consider minor problems with it. First my full bale switch isn't working but I can work around that. The problems I am more concerned with is that the twine isn't being cut off as it should. It isn't dumping the rolls out as it should either. The problem with the twine seemed to be getting better the more it has been used but still not cutting properly. The dealer told me about the dumping out problem before I bought it and he said it needed bottom belts so the bottom belts were replaced before I agreed to purchase. I am pulling the baler with a Massey Ferguson 175 and it seems to be strong enough to handle it without any problems. Any insight would be greatly appreciated.
KEH
05-29-2007 18:01:29
 Re: Case IH 3450 Round Baler in reply to MAH, 05-29-2007 09:17:44
Don't know about that baler, but on others I have put on a new knife to solve the cutting problem. On one I wound up making a wider new knife out of an old mower section.
KEH
