root rake for a JD 450c
Mark Cutting
05-26-2007 20:05:55
Does anyone have any tips for using a root rake for a JD 450C? I need to clear about 3 acres of land that has been stumped already. I have a root rake but have never used it. Will it pick up rocks too or do I need a york rake? How deep do I set the blade? How do I avoid piling up too much soil with the roots? Thanks.
Mark
2x4
05-26-2007 21:27:07
 Re: root rake for a JD 450c in reply to Mark Cutting, 05-26-2007 20:05:55
just set the teeth to go as deep as you want by using the blade to push the teeth down while moving slowly. The blade should not be digging, only shoving what the teeth dig up.
2x4
05-26-2007 20:24:33
inside 6 way blade or outside blade?
Mark Cutting
05-26-2007 21:16:38
 Re: root rake for a JD 450c in reply to 2x4, 05-26-2007 20:24:33
It has a 6 way blade
