drum mower
steve in tenn
05-23-2007 15:28:02
I have picked up a 165 vermeer drum mower that needs the bottom saucers and some sheet metal work. My question is are they worth fixing and are they better or worse than a disc mower? Thanks
Hay DR
05-24-2007 15:31:25
 Re: drum mower in reply to steve in tenn, 05-23-2007 15:28:02
third party image
The Vermeer 165 drum mower was made by PZ and most of the current HayMAXX-CCM 165 drum mower parts are interchangeable. We have the bottom saucers in stock, Part # 170-2-66. The saucers are held on with 3 allen head bolts.
Sid
05-24-2007 18:58:51
 Re: drum mower in reply to Hay DR, 05-24-2007 15:31:25
I have heard the claim hay will cure a little faster if cut with a drum mower than a disc mower. Izzit so?
Hay DR
05-25-2007 02:37:02
 Re: drum mower in reply to Sid , 05-24-2007 18:58:51
Both the disc mower and drum mowers cut hay in the same manner. There is no difference between them in drying time.
Kelly Campbell
05-24-2007 06:43:12
FYI this drum mower is made by Agrostroj Pelhrimov of Czechoslovakia there very good mowers and for the most part easy to maintain, they have only about 8 moving parts in them. I have one sitting in the yard that I'm replacing a shoe on as well as knives. heres a link to there website.
Lincoln
05-23-2007 16:53:06
I have a Reese drum mower. I haven't had a chance to really try it out yet, but it seems to cut good so far. My drums are beat up and in bad shape. The drums cost $1053 each so I'm kind of in the same boat you are about replaceing them.
Hay DR
05-24-2007 15:33:48
 Re: drum mower in reply to Lincoln, 05-23-2007 16:53:06
The HayMAXX saucers list for $150 each.
David Snipes
05-24-2007 12:30:38
I have been considering getting a drum mower. What would cause the drums to get beat up? Does anyone know how long they last? If a field is clean, I thought the drums would stay in pretty good shape.
Sid
05-24-2007 18:56:30
 Re: drum mower in reply to David Snipes, 05-24-2007 12:30:38
sounds to me like it was used to mow hay by day and sprouts by night.
