David Bradley Manure Spreader
Bob Lang
05-23-2007 12:52:24
I need to find parts for a ground driven speader.
mainly a chain sprocket.
I could use some help.
thanks
nballen
05-23-2007 13:37:30
 Re: David Bradley Manure Spreader in reply to Bob Lang, 05-23-2007 12:52:24
Unless you are trying to keep the implement in "original" condition, any ag parts / farm store should have generic sprockets. They will probably be "single-pitch" while the one you are replacing may be "double-pitch".
If you have a double-pitch chain (long space between links) a "single-pitch" sprocket will work just fine. Match the chain pitch and outside diameter, find a weld-in hub with the right diameter, weld the two together. (Sounds simple, huh?!)
Nathaniel
Bob Lang
05-23-2007 14:20:06
 Re: David Bradley Manure Spreader in reply to nballen, 05-23-2007 13:37:30
Thanks just need to get it working. I will look in ag stores.
nballen
05-23-2007 15:23:49
 Re: David Bradley Manure Spreader in reply to Bob Lang, 05-23-2007 14:20:06
You didn't say where you are located, but around Boise, ID (all crops are grown under irrigation) a sprinkler / pipe house has THE BEST selection (and very competitive price) of any one around.
So ask around, you might be surprised where you could find suitable parts.
You have a welder?
Bob Lang
05-25-2007 11:34:53
 Re: David Bradley Manure Spreader in reply to nballen, 05-23-2007 15:23:49
I can weld. I will check out the irrigation parts co.
Thanks P.s. Iam in OHIO. we need irrigation equipment right now.
