NH 848 baler problems
tom-ky
05-22-2007 20:00:34
Having a hard time getting it to start a roll in short hay. Tries to throw it back out of the pick up. Any suggestions?
Allan In NE
05-23-2007 04:20:41
 Re: NH 848 baler problems in reply to tom-ky, 05-22-2007 20:00:34
Tom,
Is the hay actually getting into the chamber or is it kicking it back out before it enters?
Is your windscreen in place?
Have you gone thru the adjustments paying attention to the main chain "empty chamber" tension and especially, in particular, the stripper roll clearance?
Is your floor roller rubber coated? Is it turning properly? If not coated, you might try spraying the roller once a year with stairway traction grit.
Have you tried larger windrows?
If it is set up properly, that machine ought to bale just about anything up to the size of a 6" post. :>)
Allan
tom-ky
05-25-2007 05:29:42
 Re: NH 848 baler problems in reply to Allan In NE, 05-23-2007 04:20:41
Allan,
I will double check all the clearances. Found out I did have a bad bearing and was throwing off the clearance. Where do you buy the stair traction spray?
JoeinMO
05-22-2007 20:10:05
Have the same baler and the same problem in real dry hay - my old 846 did the same thing also. I throttle down until the core forms, then speed back up for the rest of the bale.
