8n dearborn 2 bottom plow
olddog5
05-22-2007 11:10:56
I just bought a dearborn 2 bottom plow for my 8n. The plow frame rubs against the PTO shaft. This is the first time I have tried to pull a plow. Any advice would be welcome.
Roger in Iowa
05-22-2007 12:08:57
 Re: 8n dearborn 2 bottom plow in reply to olddog5, 05-22-2007 11:10:56
Are the lift arms trailing the tractor equally or are they offset when plowing? If offset, you need to adjust the plow by the member where the lower lift arms attach. If the tractor tires are properly spaced the plow should be centered directly behind the tractor and the first lathe (share) or what ever you want to call it should be taking a full cut.
Roger in Iowa
