Adjusting Slip-Clutch
RoyceTN
05-21-2007 13:29:07
Just bought one of these to mount on my 6' cutter. Did not come with any instructions. What is the best way to adjust it?
RodInNS
05-21-2007 13:55:36
 Re: Adjusting Slip-Clutch in reply to RoyceTN, 05-21-2007 13:29:07
There is generally a dimension given for the spring length in the operators manual. I'm guessing that you don't have a manual....
In that case, adjust all the springs to the same length, and generally just bring it up tight enough to cut heavy grass and work decent.... but you want it loose enough that it will still slip if it hits something. That's the basic idea anyway.
Rod
