no 5 flywheel
joelrand
05-21-2007 10:21:25
I have the flywheel off the jd #5 sickle mower, a new key also, now how do I get it back together? put it on the shaft then hammer the key in or try to work both on at the same time?
IaRalph
05-21-2007 11:07:58
 Re: no 5 flywheel in reply to joelrand, 05-21-2007 10:21:25
Tell us about that tractor. Looks like a 41-47 1/2 B with spoke wheels, and cushion battery box seat. Some one did some changing.
James Howell
05-21-2007 10:53:24
third party image
I agree with Rich. Turn the crankshaft until the keyway is on top. Slide the crank wheel back on and align the keyways. Insert the key stock.
As a suggestion make sure you grease the box bushing on the pitman plate.
Be careful and key your finger away from the knife!
Hope this helps.
Rich Va
05-21-2007 10:30:03
When I put mine back together I put the flywheel on then drove the key in,then with a hacksaw cut off the excess. Works fine,no problems. RVa
