Farm Tractor And 16 row planter Recovered
El Toro
05-21-2007 06:24:58
Here's a tractor and planter that didn't quite make it to the field. The driver probably had to change his pants too. This was in Elwood NE. Hal
third party image
third party image
Gary from Muleshoe
05-25-2007 05:53:12
 Re: Farm Tractor And 16 row planter Recovered in reply to El Toro, 05-21-2007 06:24:58
The only ones that will ever know how scared he was is him and the lady that does his laundry.
El Toro
05-25-2007 06:06:46
 Re: Farm Tractor And 16 row planter Recovered in reply to Gary from Muleshoe, 05-25-2007 05:53:12
I have 7 more pictures that I never posted. If you want to see them email me and I will send you a copy. Hal
El Toro
05-25-2007 06:03:33
The best part is the farmer wasn't injured and has the planter repaired. He's busy planting crops. Could've been a lot worse if he was on that tractor if it fallen into the irrigation canal. Soap and warm water will care of his pants. Hal
Billy NY
05-21-2007 20:26:52
2 all terrain hydraulic cranes, one on left looks to be 175-200 ton + or - and the one on the right looks to be heavier, 200 or 300 ton + or - each one of those in this area would be around $2000-$5000/day + 1 operator & 1 oiler each crane (4 operating engineers pay), remote location - mileage too ? Hard to say on that, and if union or non union for operators payroll costs, don't know the area or the company.
Also a truck crane, wonder what they used it for ? (could be up to another $2000/day for one of those) & 2 tractor trailers on site, one looks like a lowbow or flatbed for crane counterweights, steel plates/timber dunnage.
It appears that the lighter capacity crane on the left is trailing the heavier crane on the right, as it's got the heavier side of the tandem pick using a 4 part spreader off a big O ring ? The seeder probably is not too heavy, so it looks like they could possibly get it in one piece and land it together towards the heavier crane. The crane on the left must have plenty of capacity over what it's picking, as the angle of the boom is going to be sharp as it gets close to land the pick along with heavier crane on the right.
That entire JD rig must not be over 30,000 lbs, guessing though, imagine the pick went like planned, have to be real careful when setting outriggers in a place like that, timbers can roll or move on soil, we used steel plates most of the time, but that was on pavement in the city, used to hire 200-300 ton hydraulics quite often. Amazing rigs.
Just out of curiosity I wonder what happened; bridge just weakened from age? Piers look ok, bracing, joists or beams failed it appears, from overloading, loose connections or just a freak thing? Sure looks like it could have been worse, that is a long drop to the water, no one got hurt, that's all that counts.
georgeky
05-21-2007 11:45:09
We hired a crane smaller than either one of those to set a slab on top of an elevater shaft in 1985 it cost 4000.00 then. No telling what this cost.
georgeky
05-21-2007 11:52:57
 Re: Farm Tractor And 16 row planter Recovered in reply to georgeky, 05-21-2007 11:45:09
I forgot to say the crane was on the job a total of 50 minutes. We already had it rigged before the crane got there. I suspect this took a while just to rig it.
El Toro
05-21-2007 12:12:27
 Re: Farm Tractor And 16 row planter Recovered in reply to georgeky, 05-21-2007 11:52:57
I don't think they would have been a rush. It was a good possibilty the rest of the bridge would give away. You need someone that knows what they're doing when rigging something like this. The government had their own riggers and the crane operators. If the crane operators didn't like what they were seeing he wouldn't make a lift. It's hard to say what the bill was on that recovery. Hal
georgeky
05-21-2007 15:07:17
 Re: Farm Tractor And 16 row planter Recovered in reply to El Toro, 05-21-2007 12:12:27
What did the government have to do with it?
El Toro
05-21-2007 16:15:36
 Re: Farm Tractor And 16 row planter Recovered in reply to georgeky, 05-21-2007 15:07:17
I was talking about in where I had worked with the Federal government. You had to have a riggers license to do any rigging and that may be required by most states. Guess I changed subjects and didn't make myself clear. Hal
georgeky
05-21-2007 18:18:14
 Re: Farm Tractor And 16 row planter Recovered in reply to El Toro, 05-21-2007 16:15:36
Maybe I just lost track. I thought you meant the gov't was lifting that tractor. Yes lots of states do require certification to rig. I use to do a lot of this as well as other construction jobs to pay the farm bills. We even rigged for helicopter lifts, mostly for AC units and such.
El Toro
05-21-2007 18:51:29
 Re: Farm Tractor And 16 row planter Recovered in reply to georgeky, 05-21-2007 18:18:14
The states may have a group similar to the National Transportation Safety Board to investigate farm accidents. If you read some of the writing in that email with 7 pictures it sounds like it is being investigated. Is there a market for tobacco now? My grand-dad raised that years ago in the early 1900's down in Sw VA. My mom was one of 13 kids and she always talked about it. Hal
georgeky
05-21-2007 20:32:27
 Re: Farm Tractor And 16 row planter Recovered in reply to El Toro, 05-21-2007 18:51:29
Hal they will buy all you can raise. The problem is that it is 50 cents a pound cheaper than before the buyout. No big deal. I seen on the news last night that gas is cheap compared to the 70s, they say wages have gone up enough to offset the price. They are full of it. Farmers for the most part don't ever get raises, they get to raise more to try and make the same money as they use to. I seen tonight that the oil companies are clearing 40 dollars a barrel on oil. When will farmers get a fair price for a barrel of corn or anything else. Granted cattle have been fairly good for a while, but everyone doesn't raise cattle. The high price of fertilizer and fuel and everything else has outpaced farm prices by quite a margin. In 1983 I got $2.12 per pound and now I get 1.50.
El Toro
05-22-2007 03:50:07
 Re: Farm Tractor And 16 row planter Recovered in reply to georgeky, 05-21-2007 20:32:27
I guess the oil companies will just add on the profits to their already billions in profits. They're not reinvesting those profits to come up with alternate fuels. I don't think they want any alternate fuel that will cut their profits.
Hal
Don Hopf
05-21-2007 09:34:05
How much damage was done to the tractor or planter?
Wonder if the insurance covered the cost of the cranes?
El Toro
05-21-2007 11:24:17
 Re: Farm Tractor And 16 row planter Recovered in reply to Don Hopf, 05-21-2007 09:34:05
I would think there would be some damage, not for sure. The insurance may have covered it. One person said it may have cost $5000.00 to lift that equipment out. Hal
