manual for a 41 mf sickle mower with pic
steven in tn
05-20-2007 15:39:57
third party image
does anybody have a manual on a 41 mf sickle mower dynabalance if so could you make me a copy and i will pay for it
i having trouble with it lopping when it running its done this since iv had it but has been getting worse. could this be a tight spot in it or a bad bearing. how easy should it be to turn by hand
Edd in KY
05-22-2007 03:57:57
 Re: manual for a 41 mf sickle mower with pic in reply to steven in tn, 05-20-2007 15:39:57
Steven, I have gone through my manual and I found nothing in there about vibration or timing. I think that mower has preset timing.
On occassion I have had the vibration problem but it ended very quicky, when I cleaned out the blade or change the PTO speed. It usually happened to me when the blade was overloaded. Does it vibrate when you lift the blade and run it free (not down in and cutting) at what speed?
Is the belt tight? Manual says "The belt should depress 3/4" to 1" at the midpoint with 20 lb. pressure. YOu may need to adjust the tensin on the belt to keep it from whipping and flopping and setting up a vibration as it goes up to speed. I had to put extra washers (spacers) on the tensioner screw. Good luck, but I don't think the manual will help here.
By the way have you greased the points in the gear box that you can only reach with the blade horizontal and the mower lifted?
Edd in KY
05-20-2007 17:43:14
I have 2-- MF41 mowers. I bought a manual from my local MF dealer. Think it cost about $15. If you don't have a local dealer I will give you the name of mine and thay will mail you the manual with a credit card purchase. They mail me most of my parts.
Not sure what you mean by Lopping?
Mine are both very easy to turn by hand if you turn the gear box pulley when the tractor is off and the PTO in neutral.
Tell me what is happening and I will tell you what i have learned about setting up these mowers.
steven in tn
05-20-2007 18:27:28
 Re: manual for a 41 mf sickle mower with pic in reply to Edd in KY, 05-20-2007 17:43:14
it is vibrating real bad when in pto speed
steven in tn
05-21-2007 08:45:56
 Re: manual for a 41 mf sickle mower with pic in reply to steven in tn, 05-20-2007 18:27:28
it seems to have a tight spot in it when i turn it it by hand but can not find it.
could it be out of time a little? how do i time it?
