jd 70 and 71 planter differnces
nick spalding
05-19-2007 18:05:16
I bought a planter that is in really good shape, but I cannot find a tag anywhere. What is the differences between a john deere 70 and a 71?
Glen in TX
05-19-2007 21:59:34
 Re: jd 70 and 71 planter differnces in reply to nick spalding, 05-19-2007 18:05:16
The 70 was earlier model and 71 later. I see the 71 flex planter is on JDs online parts catalogs but the older 70 is not.
Dsvfarms
05-19-2007 18:16:48
The main difference is the drive chain adjusts by sliding the wheel on the 70's. On the 71 the wheel is fixed and the chain has a spring loaded tensioner.
John e.c.MI
05-20-2007 09:09:53
 Re: jd 70 and 71 planter differnces in reply to Dsvfarms, 05-19-2007 18:16:48
Also the depth is adjusted differently. The 71 has a depth cam which you rotate, the 70 has a slotted arm that you loosen a carriage bolt to adjust.
