JD #9 Sickle Mower
wyatt O
05-19-2007 01:29:19
Was wondering if anyone can e-mail me basic set up diagrams and instructions to set up a #9 JD mower. I don't really want to buy a manual?
Glen in TX
05-20-2007 11:23:00
 Re: JD #9 Sickle Mower in reply to wyatt O, 05-19-2007 01:29:19
Can probably find a manual on online auctions like ebay or ads cheaper than JD.
North TX No9
05-19-2007 20:50:44
What tractor are you trying to hook it up to?
In the back of the manual they show connections for different tractors. I could scan the page for your model. I probably could have winged the hook up with out an operator's manual but I would never have realized the lift spring was broken without something to compare to. And I wouldn't have know where the eccentric bearing was to set the primary lead. And I wouldn't have known there was supposed to be a bolt through it. And I wouldn't have know there was secondary lead to set. And I wouldn't have realized I was missing the inner sub shoe, etc, etc.
m sb
05-19-2007 19:55:47
What do you need to know? There are two different styles of attaching brackets, depending on the size and shape of your 3 point hitch arms.Older and or smaller Deere tractor arms are square and the 3010 on up used a sort of round arm.The brakets are fastened to the lift arms with U bolts.
Adjust the center length to to the give you the raised height on the outer end of the cutter bar that you want.
I had a 9W mower for years and I loved it. Too bad I crossed that ditch wrong and broke the gearcase.Scrapped it.Now why didn't I think to keep those brackets?
