New Holland Haybine
backwoodsfarm
05-15-2007 18:51:50
I recently changed the upper roll drive oil seal off the top main gearbox on my NH 474 Haybine. Now I"ve got oil leaking from somewhere else. It seems I"ve chased oil leaks on the main gearbox forever. I was wondering if anyone has ever said to heck with the gear oil and packed these things with a good high grade bearing grease. The machine mows about 100 acres a year.
backwoodsfarm
05-17-2007 05:30:28
 Re: New Holland Haybine in reply to backwoodsfarm, 05-15-2007 18:51:50
Thanks for the help guys. I think I'll find some of that 00 grease and go from there. Thank God hay season is here and/or on the way! Been a really long winter in Maine!
backwoodsfarm
05-16-2007 13:00:29
Jimmy- How long can I run it with the grease? Forever, or just until I can fix the oil leak? It is almost time to upgrade to a newer mower.
Jimmy King
05-16-2007 10:10:50
Put 00 grease in it, you may have to look several places before you find it. Snapper lawn mowers use it in their gear boxes, but it will break you up to buy it from them. I buy it in a 5 gal bucket.
Jimmy King
05-16-2007 21:34:23
 Re: New Holland Haybine in reply to Jimmy King, 05-16-2007 10:10:50
I use 00 grease in all my gear boxes permantly. It will flow but not leak through seals easly. It will pour like oil only slower.
troy21
05-15-2007 21:41:38
do as i do.. drill the plug for a grease fitting and just shoot some n it ever time u grease the rest
mn.Chuck
05-15-2007 19:55:05
Hi, This was not normally a problem on any of the
NH haybines. The haybine runs only in warm weather
and if I were you I would use good grade of gun
grease. They did this with the complete line of
rakes years ago. The dealers all got bulletins to
use gun grease. Same type of gearing so I'd go for
it at least to get you thru the season. Chuck
Rexalot
05-16-2007 22:06:18
 Re: New Holland Haybine in reply to mn.Chuck, 05-15-2007 19:55:05
Sounds like my 469... I just packed the gearbox full of "marine" grade wheel bearing grease.
