georgeky
05-14-2007 20:27:43
Re: How to adjust, tune, sharpen or repair a sickl in reply to Edd in KY, 05-14-2007 17:39:16
Hi Edd, First of all for what it is worth, I to am not to crazy about disk mowers. I have two of them that sit in weeds. When new they were the cats meow, other than throwing crap all over me. Once they are worn out they are worn out. I am using cycle mowers that are almost 60 years old. I have used the MF mower a little, but am not real experienced with them, but all cycle mowers are basicly the same. As for the double rock gaurds, I assume these are light duty combine gaurds. If you have no rocks they are very good. I haven't seen them cost 30 dollars though. Around here they are usually cheaper than two single rock gaurds. On sections, myself I use the under serrated kind. I sharpen those on the top side free hand with a 4 inch hand held angle disc grinder.I very rarely buy a whole new cycle, unless it breaks, I keep putting sections on it. I run gaurds until they are bent or have the tip broken off, I have never tried to sharpen the ledger plates. The gaurds are adjusted with a good 2 to 3 lb hammer. There is a gauge you should try to find that will make sure you have the right pitch on them. The plugging is usually caused by very fine grass that just sits at the end of the ledger and goes back and forth. Bluegrass and cheat(not sure of that spelling) are the worst as far as ease of cutting, they will make your mower rattle to beat the band, even in top shape. Those are the two grasses that plug up the gaurds the worst. Hairy Winter Vetch is a nightmare to mow as it clings to the gaurd bolts and most any part of a mower. I adjust my hold down clips with the same hammer that I adjust gaurds with. It is important especially in that fine grass. Grasses such as fescue,orchard grass and timothy are not as picky and are easy to mow. I have used IH,JD,AC,Ford,MF,NI and NH mowers. The best ones are IH and NH. John Deere had some good mowers as well. But at the end of the day nothing beats the IH or New Holland mowers. I do have a JD 1207 Mower conditioner that is a real machine, I use it a lot as well. We usually run three at a time. I say that I cut hay today, but in reality my two sons and life long friend done all the mowing, I just ran back and forth with Ale8s and water. Managing my mother calls it. I am not sure about the sound, my mowers sound different from one type of hay to the next. Sometimes if they rattle and bang to much you do have a problem with loose rivets/bolts,gaurds or timing. Most balance head mowers do not need to be timed, except when pins and such are worn out, then replacing them is the only alterative, but these old IH pitman mowers do need to be in proper time, and are adjustable. I am no expert, but I hope this helps some.
