massey sickle bar mower
steven in tn
05-12-2007 18:36:17
third party image
does any body know if there is any thing missing on the end?
top is the newest pic.
georgeky
05-13-2007 08:51:35
 Re: massey sickle bar mower in reply to steven in tn, 05-12-2007 18:36:17
At MF dealor or any other. TSC has a uviversal model made of a steel plate with a couple of rods sticking out of them. One is twice as long as the other. Or you can call Brad at 1888-824-0544 and he will send you one.
georgeky
05-13-2007 08:47:49
At any MF dealor or any other for that matter. TSC sells universal swath boards. It is just a metal plate with a couple of rods sticking out of the back end of them.
02
05-13-2007 01:31:03
I like the serrated sicle sections rather than the smooth ones you have.I also notice what looke like new hold down clips. Google up sicle bar hold down clips and you will find the Stern hold downs which are spring loaded and really help keep the mower from plugging.You can buy new a new sicle at your Ford New Holland dealer for a reasonable price.
steven in tn
05-12-2007 20:53:16
third party image
this one looks just like mine but is has a different end section than mine.
Sid
05-12-2007 18:53:35
Like georgeky said, those guards will cause problems. Can't tell for sure but that ledger plate looks worn or missing. If it were mine I would take that last section off the sickle and put a special end section in its place. They kinda look like a section and a half.
georgeky
05-12-2007 18:47:39
Looks to be there. You need to take off that bent gaurd and any others that are bent or have broken tips. These like that will not cut anything, stay plugged up all the time.
steven in tn
05-12-2007 20:24:17
 Re: massey sickle bar mower in reply to georgeky, 05-12-2007 18:47:39
third party image
latest pic
georgeky
05-12-2007 23:19:01
 Re: massey sickle bar mower in reply to steven in tn, 05-12-2007 20:24:17
If that is yours it needs a swath or grass board as some call it. It leaves a clear streak on the ground to run the mower shoe in for the next round. It fits on the end, bolted on through that hole you see in the photo.
steven in tn
05-13-2007 07:16:49
 Re: massey sickle bar mower in reply to georgeky, 05-12-2007 23:19:01
any body know where i can get a swath or grass board?
02
05-13-2007 22:20:04
 Re: massey sickle bar mower in reply to steven in tn, 05-13-2007 07:16:49
Easy to make.
