Hillers
J. Risher
05-11-2007 16:58:24
I went to Agri Supply and found some 12 inch hillers w/16 inch shanks. Has anyone here bought these to use on the Farmall tractors. I need another set as mine are wore out. Thanks, John.
Jim in NC
05-12-2007 02:40:14
 Re: Hillers in reply to J. Risher, 05-11-2007 16:58:24
Bought a set years ago. Still goin' strong. I use them in tobacco and the garden.
johns48jdb
05-11-2007 19:24:39
you may know this already but to lay by corn with hillers put one disk in front of the other one. that way one disk will push the grass over flat and the other one will cover it up. if you put them straight across then you'll have a corn field that looks like a mohawk hair cut.
Jim in Ma.
05-11-2007 18:00:22
Hi Joh - I use them on my Cub, I have 2 sets - one is w/streight shank and the other is off-set shank.
They work good for dif.applications
Jim
J. Risher
05-11-2007 18:05:42
 Re: Hillers in reply to Jim in Ma., 05-11-2007 18:00:22
Jim Do these fit the Farmall's, I am sure the ones that are listed @ 1 1/4 inch in diameter will fit and there is a 12 inch disc which is what I now have. Have you ordered from this company before. I use them to pull dirt up to the potatoes and corn.
