Flange bearings on a JD 1209 MOCO
Scott(MO)
05-08-2007 20:49:01
Hello, I'm changing flange bearings in my mower/conditioner and those things are a bear to get off. Do any of you all have any suggestions? The only way I know is with a torch, but I hate doing it that way.
Scott
paul
05-10-2007 20:09:12
 Re: Flange bearings on a JD 1209 MOCO in reply to Scott(MO), 05-08-2007 20:49:01
I see I'm in good company with the torch. :)
I spend about 5 minutes with a hammer, chisel, prybar. Then roll the torch over & get it over with. Seems 4 get the torch for every one that slips off like 'supposed' to.
--->Paul
johns48jdb
05-09-2007 18:44:39
on ih 990"s years ago the bearings were held in place with a collar that twisted onto the inner race of the bearing and that collar was held in place with a hex set screw. may be two screws sometimes. have you got the locking collar type on yours?
JMS/MN
05-09-2007 10:55:56
ALWAYS keep the torch parallel to the shaft- never direct it to the shaft. Don't hit the torch lever until the target metal is bubbling. Lower the Oxy valve if you're worried about burning the shaft- when getting close, let up on the lever, let the torch head bubble the last bit of bearing away from the shaft. That miniscule bit of space between the shaft and bearing will stop the cut. Minor scrapes are ok- I've done hundreds of bearing cutoffs and never ruined a shaft. Just don't get wild with the oxy lever.
Jerry C in NC
05-09-2007 05:28:34
Torch it. Been there done that... Only way to get it
RickB
05-09-2007 03:18:03
No reason to hate using a torch. It's the best way I've found. A little practice and you won't even nick the shaft.
