clearing small are of brush/stump
Boyce
05-08-2007 06:22:35
Hello gang! Need advice on what equipment to rent/beg/borrow! I have a area approx. 15X40 that has a good deal of brush, along with many 1-2" saplings, and a 6-8 inch stump. I'd like to clear that area, and possibly grade it a little more level. What do you guys recommend for this? If I can buy something for a few hundred dollars, I'd rather do that than rent a tractor for a few hundred dollars...
johns48jdb
05-09-2007 19:13:52
 Re: clearing small are of brush/stump in reply to Boyce, 05-08-2007 06:22:35
hire a guy with a back hoe and let him dig the stumps up. if your are going to hire a back hoe to dig them out you may want to wait until after he digs and pushes the trees over. if you cut them off he want have any leverage to use against the roots. let him push them over and then saw them up. cut the stumps off while he's there and let him haul them off. this will require some fill dirt for the holes. if you don't do it this way, don't haul off your trash - use it to burn the stumps out. ice cream freezer salt will kill any tree. i cut slots in the stump and pour the salt to it.
Wisconsin Cowman
05-09-2007 18:42:26
I would say some gas and a lighter and have a controlled fire. That is the easy way.
Dave H (MI)
05-09-2007 11:53:14
My preference? Cut the saplings and stump, fence the area and run some goats in.
Dave H (MI)
05-09-2007 11:53:06
ed1
05-09-2007 06:04:27
For the price your talking about grab an axe and shovel and plan on it taking all summer to clear.
The least expensive quickest way I can think of is to buy a cheep chainsaw for a couple of hundred dollars and rent a skidsteer (bobcak. new holland, etc) for around $500.
Use the skidsteer to clear up everything but the big stump.
For the big stump you have 2 options.
- Dig down with the skidstear and cut the roots with the chainsaw then lift out
- Cut the stump at table height and make a garden table out of it.
Now that pile of brush? What to do with it?
Boyce Rampey
05-09-2007 06:19:11
 Re: clearing small are of brush/stump in reply to ed1, 05-09-2007 06:04:27
Fortunately, I already own a chainsaw. So I can cut everything down to a managable height, then dig around the roots I guess. Maybe I can use my garden tiller to get some of the small stuff. At least I can till around and loosen up the soil before getting my shovel out! Thanks again to everyone!
James Howell
05-08-2007 10:35:55
Steve has a good idea on using a chain saw. Be careful with the chain saw. I have been using chain saws safely for over 40 years and have the scars to prove it!
I use a �grubbing� hoe to clean around the base of the tree to be cut. This allows you to really cut at ground level.
Use the excess dirt to cover over the stump.
Next year if /when the tree sprouts up from the roots, go to Tractor Supply and buy a product called REMEDY.
Spray the leaves on the new growth with REMEDY. This will kill the roots and the stump.
My favorite wife has been very successful over the past few years killing Persimmon, Sweet Gum, Kudzu, and Bois de Arc ( Bodark )stumps with REMEDY.
Be patient. The dead stump will be taken over by ants, grubs, termites, etc. They will help �decompose� the dead stump.
Be patient. The armadillos will tear up the decomposed stump to eat the ants, grubs, termites, etc.
We use �loppers� to cut the small brush ( �� � 1�� ) off at ground level.
If you use a tractor with a rotary mower to clear the brush, be sure to come back and use the loppers to cut the �stobs� off at ground level. That helps eliminate any future tractor flats.
Disk or till the ashes from the burn pile. Only grass/plants/weeds with deep roots should grow back.
Hope this helps. Good luck with you clearing and work safely.
georgeky
05-08-2007 07:52:35
Those mini excavators are slick outfits. I rented one about two years ago and it cost 116 dollars for half a day.
BCnT
05-08-2007 07:49:13
i've cleared alot of small brush with a chain and tractor...takes awhile and usually costs a sore back but no stumps to dig out later.
steve from mo - dangit!
05-08-2007 07:08:09
 A determined man with a chain saw. in reply to Boyce, 05-08-2007 06:22:35
Here's my approach. That's not a very big area to clear by hand. The only real hard work involved is removing that stump, and it's only hard if you are impatient.
Start at one end cutting the trees off at ground level with the chain saw until you have too much brush piled up to work around. Then haul the brush off off to a burn pile. Repeat until you're done.
If you really want the stump gone, dig around it and cut the roots. Most of them go out laterally. You can cut them with an axe or a mattock.
You'll need to mow this area regularly for a couple years to keep the suckers down that will come up from the roots.
Boyce
05-08-2007 07:23:49
 Re: A determined man with a chain saw. in reply to steve from mo - dangit!, 05-08-2007 07:08:09
Thanks for all the advice guys. I'll try the chainsaw thing first, maybe just concentrate on a small area at first to see how it goes. I've owned the porperty for 15 years, and plan to stay, so I can get it done a little at a time!
JMS/MN
05-08-2007 07:03:56
Rent a mini-excavator with a toothed bucket. Usually has a backfill blade on as well, can level with that. Rips out the brush, can dig out the stumps.
Ken Macfarlane
05-08-2007 06:35:03
The cheapest way is time. Those stumps will come out with hand tools in a few years normally. You won't find a really small piece a equipment that can pop 6-8" stumps. A portable stump grinder can get rid of them to below grade though. The brush is handled with a bushhog or clippers.
Boyce
05-08-2007 06:47:01
 Re: clearing small area of brush/stump in reply to Ken Macfarlane, 05-08-2007 06:35:03
I was thinking of something with a bucket, or scrape blade, and hopefully it would have enough umph to cut off the smaller saplings/brush, and level at the same time. I've seen a few neighbors with tractors that have a loader type bucket. Wonder if that would work? Best thing I guess is get one of 'em to come take a look. It's mostly sandy here in Columbia, SC so I don't think it will be too big a job for someone with a light tractor. I'm just not well versed in the uses of say a disc harrow versus, a cultivator, or a scraper blade. I even thought of buying a cheapish small scrape blade, and making an attachment to put in the receiver of my one ton truck. I'm afraid I may just bend the frame though!
KEH
05-08-2007 18:48:31
 Re: clearing small area of brush/stump in reply to Boyce, 05-08-2007 06:47:01
Boyce,
A scrape blade will not cut anything of any size. A front end loader bucket is not a bull dozer and should be used very carefully on even small saplings. I would do the chain saw approach like the other posts said. Paint the stumps with a mix of, I think, one part Remedy to 3 parts diesel fuel. Directions should be on the can. I hope it is availiable in less than gallon sizes as a gallon is over $100. I have had good success painting the stumps this way. Paint just after cutting. As for the big stump, it has been suggested on here that a bag of charcoal on the stump will burn it up. I have never tried that. Don't think the truck is suitable for any of what you suggested. I'm also in SC, near Spartanburg. Good luck.
KEH
