Kutter
Russ from MN
05-06-2007 08:21:32
We have a King Kutter (5' lift) that we have used and misused for about 8 years, to often as a rock crusher! It seems to be shearing pins more frequently all the time, and I think the u-joint yolk is worn some. does anyone think this contributes to the bolts shearing, and can you buy just the yolk? King Kutter only lists the complete drive shaft. Thank you
IaGary
05-06-2007 08:32:30
 Re: Kutter in reply to Russ from MN, 05-06-2007 08:21:32
If it is a common yoke then yes you can just replace the cross. NH and some others have there own style of pto crosses.
TSC, repair shops and bearing shops can help you get the right one.
Gary
