IHC 2point Mowing Machine
Richard E Smith
05-06-2007 04:50:30
Hello,
Could someone please inform me on how to set the lead on an old 1960`s IHC mowing machine.
Thanks
Richard E Smith
Monticello,Ky.
Richard E Smith
05-07-2007 01:15:07
 Re: IHC 2point Mowing Machine in reply to Richard E Smith, 05-06-2007 04:50:30
Thanks very much for all the answers,You`all have been a great help. I`m using a 300 Utility International Tractor.
Thanks to your help I now know what the chain on one side and the very long bolt with mount on the other side is for..... I think ,ha,ha.
Thanks again
Richard
Richard E Smith
05-12-2007 14:05:48
 300 internatinoal tractor in reply to Richard E Smith, 05-07-2007 01:15:07
Thanks for the help on my hay mower, found out that the big round pipe in back was bent !!!
Now could someone please tell Me were I can find 2 new Reactor Bands for the PTO on my 300 IHC tractor. Or a place in Ky to get them relined .
Thanks Richard
georgeky
05-07-2007 06:27:43
 Re: IHC 2point Mowing Machine in reply to Richard E Smith, 05-07-2007 01:15:07
Some how I missed the part about the long bolt. In that case one chain is all you have.
georgeky
05-07-2007 06:24:10
There should be two chains. One to lift the cycle and one to stabilize the mower. The one on the lift mechanism hooks to the bottom of cylinder and the other hooks in a bracket on the lifts rockshaft.
Vapet
05-06-2007 09:56:45
On the pitman type adjust the trip link eye that goes into the frame that holds the cutter bar till you have 1 - 1.5 inches lead on outer end of bar. Don't remember if some of the balance head mowers had an adustment. Have manual somewhere.
georgeky
05-06-2007 10:26:57
 Re: IHC 2point Mowing Machine in reply to Vapet, 05-06-2007 09:56:45
Most of the problem is in the fast hitch itself. They are old and tend to run sideways when mower is in hay. Some of the pitman mowers have a bracket that attaches to the axle of tractor that will help this. The balance head mower has a chain to hook back to the tractor to help with this. Other than that there is no adjustment on the balance head mower. The pipe arm on the C-24-P and C-21-P mower can also be sprung back to adjust this.
georgeky
05-06-2007 07:30:49
Which mower do you have? The older pitman mower, or a 100 balance head mower.Also which tractor are you using it on?
flying belgian
05-06-2007 05:55:39
with any sickle mower you set the lead a whee bit positive. during operation it will sway back to deadon.
IaGary
05-06-2007 05:09:38
Are you refering to a sickle mower?
If so,what do you mean by lead? Angle of the guards?
Gary
