Sprayer Pump Question
super991/2
05-05-2007 19:47:37
The centrifical pump is going out on my old sprayer. I am wondering if a roller pump would work? I'm spraying Roundup and liquid AAtrex and will go back later with Liberty and more Aatrex. Plan to switch it over and use it to sidedress liquid N later on. Will a roller pump give enough volume to work or do I need to get a new centrifical pump? Thanks, Chris
Jerry/MT
05-06-2007 21:12:28
 Re: Sprayer Pump Question in reply to super991/2, 05-05-2007 19:47:37
If you're going to use Roundup in a pump you'll have to get one that has a special alloy housing as Roundup is acidic and will eat up a cast iron roller pump. I don't know what your flow rates are but roller pumps have a wide flow range. Try www.hypropumps.com.
IaGary
05-06-2007 04:43:11
Is it an Ace centrifical pump?
They are rebuildable to get longer use out of it.
Depending on which roller pump it is, yes some are low volume. If it has steel rollers nitrogen may be hard on it. Nitrogen is hard on all pumps.
Clean and flush the pump well when finished with it.
Gary
