7000 planter help needed
GRB054
05-02-2007 11:10:57
Have to replace the countershaft in my JD 7000 6RN and ordered replacement from Shoup- comes in two pieces that you bolt together- is there a right way to install? Guy helping me cut up the old countershaft with a torch before I could measure the holes
pbutler
05-08-2007 12:32:54
 Re: 7000 planter help needed in reply to GRB054, 05-02-2007 11:10:57
"Junction" goes on the left side of the planter. It is important to get the holes lined up right.
dboll
05-02-2007 12:02:04
I am not going to help you with your problem but we have had shafts made at the local machine shop for lot's less $$ Should be able to reference it as to where the clutch goes if thats the shaft we are talking about.
GRB054
05-02-2007 12:11:51
 Re: 7000 planter help needed in reply to dboll, 05-02-2007 12:02:04
tried local machine shop route- couldn't get anyone to make one w/o a good one for them to use as a guide- I have heard the holes for the clutch are offset about a 1/4" and wwould like to find out before I put everything together
t cook
05-03-2007 16:46:32
 Re: 7000 planter help needed in reply to GRB054, 05-02-2007 12:11:51
Your deere dealer should be able to get the specs from deere for you. If they want to make a call.
