wooden bearings
fredmich
04-26-2007 18:54:06
Does anyone know a source or website for the wooden bearings that some of the old discs and cultipackers used? Thanks ..Fred
oxrus
05-25-2007 21:34:53
 Re: wooden bearings in reply to fredmich, 04-26-2007 18:54:06
use red oak
johns48jdb
04-27-2007 13:57:14
i would think that adding a little heat to the bucket half full of oil would help make it soak in. don't use to much heat. just a slow smimmer.
Steve Crum
04-26-2007 21:41:47
You might want to check with some of the mill supply operations. A good many feed mills have augers etc, that use wood bearings in the carriers of long screws. (wood fibers are safer in feeds that metal shavings). We use several wood bearings at work. Most are straight grain hard maple from the looks. I'm not sure where they are ordered form. I won't be back to work until Monday to find out, sorry.
JOHN HARMON
04-26-2007 19:34:28
YES: If you live in the midwest find a Fence Row of Osage Orange [Hedge Apple], chop off a 6" around Limb, and cut out your own Wood Bearings.Thats what we used to do for all the old Tools that had wood Bearings. Cut a Block the right size, Drill the Shaft Hole, drill the Hanger Bolt Holes and cut it in half and install. You are back in buisness.
Ken Crisman
04-26-2007 19:11:40
I've seen them on ebay a couple times . I can't seem to win them tho . If ya find a source , please let me know . i need quite a few to get my disc back in shape . If I could get ahold of a new set I'm sure I could make some on my wood lathe . My email is [email protected] . God bless , Ken
Dyno Denny
04-26-2007 19:04:55
Years ago my uncle made some for a disc out of hard wood (oak,i think) and soaked them in a bucket of oil for quite while. It seemed to work well. It might be worth a try.
