Pumpkin Seed Plates
Adam IH
04-26-2007 15:51:31
Hi,
I ordered a set of John Deere Pumpkin Seed Plates, but I am not using them in a John Deere planter, I am using them in an Allis Chalmers planter with the John Deere adapters, do I need a filler ring for the Allis Chalmers planter like you do for the John Deere planter? Thanks to everyone in advance.
LA in Wi.
04-28-2007 05:55:30
 Re: Pumpkin Seed Plates in reply to Adam IH, 04-26-2007 15:51:31
Lincoln Ag Products can answer your questions best. Give them a call 402-464-6367. They are specialists in planter plates. To use a JD plate in an AC you need the "AC Adapter" to make the plate rotate.
John e.c.MI
04-27-2007 19:56:39
I think you will still need the filler ring. The pumpkin plate is thinner than a corn plate.
farmerweber in PA
04-26-2007 18:53:36
I'm doing the same thing with an Allis planter,but with corn plates.I think you will have to use the fillers,but I'm not positive about that.Was going to do the same thing you are last year but ended up buying a one row Cole planter off a friend of mine.Curious about what you find out for sure.
