size of blade for 8n
Tom Tiedt
04-26-2007 13:37:40
Hi,
I just puchased a Ford 8n, my first tractor. I'm getting mixed answers on what size of blade to buy for gravel and snow work.
Dealers are telling me I need a 7ft.,some people tell me a 5ft. is all the tractor can handle and i'm considering a 6ft.
Can anybody help me here? Who's right?
Thanks,
Tom
Ken Crisman
04-26-2007 15:25:13
 Re: size of blade for 8n in reply to Tom Tiedt, 04-26-2007 13:37:40
You don't want any bigger than a 6' blade . A 7' will lift the front end at times & you may get hurt or damage something .Njoy the new toy . God bless , Ken
Tom Tiedt
04-27-2007 08:02:11
 Re: size of blade for 8n in reply to Ken Crisman, 04-26-2007 15:25:13
Thanks a lot Ken
Tom
Pooh Bear
04-26-2007 15:04:55
I have a 6 footer that my 8N pulls real well.
Pooh Bear
Tom Tiedt
04-27-2007 08:04:14
 Re: size of blade for 8n in reply to Pooh Bear, 04-26-2007 15:04:55
Pooh Bear,
Thanks for your help
Tom
old
04-26-2007 14:30:25
An 8N will pull a 7 footer in most stuff but the problem is they can weigh to much to lift them up and keep the front end on the ground. I use a 6 foot on them a lot and they work well if light enough. My one 6 foot I can't use on an 8N because its real heavy and picks the front tires off the ground if I try. So you have to make sure the blade is less then 800LBS or it will cause you problems
Tom Tiedt
04-27-2007 08:06:34
 Re: size of blade for 8n in reply to old, 04-26-2007 14:30:25
Old,
Thanks for your input.
Tom
D.B. in Mi.
04-26-2007 15:50:35
I was going to get a 7ft blade for my 8n, but a local tractor shop told me that if I wanted to turn the blade around to do some push blading it would hit on the tires, so I bought a 6ft and it works fine.
Tom Tiedt
04-27-2007 08:08:22
 Re: size of blade for 8n in reply to D.B. in Mi., 04-26-2007 15:50:35
D.B.,
Thanks for help.
Tom
