Need Parts/Parts ID help for Allis #7 sickle Mower
Galen ishman
04-26-2007 07:59:45
Hello..I am trying to find some parts or parts identification for what is I believe an Allis Chalmers #7 trailer type sickle mower...On the bottom of the gear box that drives the sickle bar there are two rotating hubs that have laminated spring steel plates that attatch to the bar which attaches to the actual cutter bar...My dad decided to mow dirt and broke the laminated spring steel pieces...I don't have a manual to give part numbers so any help is appreciated..thanks!!!!
Traditional Farmer
04-26-2007 08:21:58
 Re: Need Parts/Parts ID help for Allis #7 sickle M in reply to Galen ishman, 04-26-2007 07:59:45
That type drive arm was the first AC put on their mowers and most ended up like yours.The parts off any of the Twin Wheel Drive mowers will work if you take the whole set up and interchange it.I have a lot of those mowers for parts
Galen Ishman
04-26-2007 11:50:53
 Re: Need Parts/Parts ID help for Allis #7 sickle M in reply to Traditional Farmer, 04-26-2007 08:21:58
Thanks for the response...If you have the parts or know the correct part names or numbers I would appreciate if you can contact me through my [email protected]
