Super A 3pt. box blade
Wesley Roberts
01-02-1999 08:22:08
I need a little help here with my Super A. I need to do some dirt work around the yard and my question is? How big a box scraper can I handle? (4 or 5 ft.) or is it a waste of time? Also if this works I will need a 3pt. for the old rig. Does anyone have a pic of a Super A with a 3pt. on it they can e-mail me? Will I need the rock shaft that bolts to the fenders to run this 3pt.? I have read some of the past post about which 3pt.is the best but if someone has a one they think works great would like to hear that also. Thanks for any help you can give. Wesley
Deutsch
01-06-1999 08:02:33
 Re: Super A 3pt. box blade in reply to Wesley Roberts, 01-02-1999 08:22:08
Wesley;
I have a Super A, doesn't have the 3-pt, just a floating blade in the back hung off a yoke attached to the shaft arms between the fenders which is attached to an arm which is attached to the hydraulic's rockshaft. I just purchased a Cub so that willl be my work tractor, the SA for restoration.
You should post to the Farmall BBS, you will get much better speedy advice.
Good Luck
