Converting a Three Bottom Plow
Twincreek
04-25-2007 10:35:19
I have a Dearborn three bottom three point hitch plow. I would like to convert it to a single bottom plow so I can use it with my 20 hp John Deere 4100 compact tractor. It appears that I can do this just by taking it apart and reassembling it as a single bottom. Am I correct? Has anyone ever done this? Will it work? Thanks for your input.
jr150hp
04-26-2007 05:21:44
 Re: Converting a Three Bottom Plow in reply to Twincreek, 04-25-2007 10:35:19
if you want to sell it i'll give you a fair price then maybe you can get the one you need. let me know JR.
Twincreek
04-26-2007 05:38:12
 Re: Converting a Three Bottom Plow in reply to jr150hp, 04-26-2007 05:21:44
Where are you located? I am in eastern PA.
johns48jdb
04-25-2007 19:04:10
wouldn't it be just as easy to sell it, but a one bottom and pocket the difference?
Leroy
04-25-2007 16:56:11
Depends on the way it is made it may be possible. If it is made with the flat bar beams and the vertical part of the beam for no. 2 bottom is unboltable you may be able to do it but if the beams are all 1 piece molded then you cannot do it as that no. 2 beam if you took the bottom off would still want to berry itself in the ground the same as if it still had the bottom on it.
shawnspeed3
04-25-2007 12:58:56
I have a Ford 3-14 3 point plow that I unbolted the 3rd bottom to make it a 2-14, so I don't see why not, as log as the plow frame is bolted together....Shawn
